I just received my new SDS100 and noticed the first time I plugged in a pair of stereo headphones that the headphone jack (which is a stereo 3.5mm TRS jack) has the 2 channels wired out of phase. There's an older thread about this from 2019 but is closed.
The same headphones receive a normal in-phase signal from my BCD160DN.
This is interesting because since 3.5mm stereo headphone jacks use a common ground for both channels, and the SDS100 is really a mono device, the headphone amp chip in there must have separate grounds for each channel. Like a quasi-balanced output.
I have emailed Uniden Customer Support asking them to forward it to their engineering team.
We'll see what they have to say. I have copied the email I sent to them below.
For now, I have constructed an adapter cable which connects the tip of the 3.5mm plug to both the tip and ring of the 3.5mm jack. This routes the output of one channel from the SDS100 to both headphone channels. It is working perfectly and sounds just fine. No straining or overload detected with multiple headphones. Here's a photo of the adapter cable:
And here's the email I have sent to Uniden Support:
Hi,
Let me preface this by saying that I’m an audio and broadcast engineer in my professional life.
I just purchased a new SDS100 and it is a fantastic scanner! With a lot of help from YouTube videos and the Radio Reference forums, I had programming setup in Sentinel even before it arrived!
And it is working great so far. Except for one issue…
Today I tried plugging in a stereo headset (tried several to be sure and an external headphone amplifier) and find the 2 channels of the stereo headphone jack on the SDS100 are wired out of phase.
Yes, the shaft of the 1/8” stereo plugs are fully seated in the jack and the shells of the connectors are not being blocked from fully seating by the way the jack is recessed from the top surface of the unit for the rubber flap.
Also, when plugged into my BCD160DN, all of these headphones receive a normal, in phase signal.
There’s an old RR forum thread about this that concluded the same but I’m not sure anyone has notified you guys about this.
In any case, this is really disappointing for such an expensive device.
Might there be a chance this can be fixed in software?
Or is it a physical design or production issue with the actual wiring to the jack or the headphone amp reversed?
If it is physical, I’ll have to build a short phase reversal cord when I want to use headphones with the SDS100. But I really shouldn’t have to 😊
Thank you in advance for routing this to the appropriate engineering team.
Best regards,
--Mark--
Hi,
Best regards,
--Mark--
