After using my scanner for a long time with no issues, I'm now getting constant low usb bus voltage errors and my scanner is not charging even when turned off. The charging light comes on but I get a battery warning and the scanner turns off. It got to the point where I couldn't even get it to come on without manually holding the cable 'just so' to get any kind of power to it.
I tried a new cable, which seemed to work better at first, but after a day or so, I'm having the same issue. It's made my scanner basically unusable.
I've ordered a powered usb hub hoping that maybe just having more power will overcome the low voltage issue...but I'm not confident it will work. I thought the next step if that doesn't work is to get an external battery charger and just not use the port for that at all. Hopefully it'll still work well enough for any programming I need to do...
My question is...would it be possible for me to just replace that usb charging port in the scanner myself and fix it that way? My son has experience with electronics and it seems like it would be a pretty minor thing to take care of and wouldn't be messing with any of the more intricate internal parts. But is that a user fixable thing or would I just be asking for trouble? If I'm going to spend nearly $100 on this to get it fixed, I'd rather spend that on a new battery/charger instead of Uniden repair service. But if it's a really bad idea to try to swap out the usb port ourselves, then I need to know that.
We're pretty DIY handy in our family but I don't want to completely ruin the scanner, either.
Thanks for any help or advice!
