SDS100 site delay
W4KRR
Coconut Creek
When monitoring a trunked system with multiple sites, is there a way to adjust the time that each site is scanned before moving on to the next site? (DMR and NXDN). Sometimes it seems to hang on each site for a very long time before moving on.
jonwienke
More Info Coming Soon!
VA
That can be caused by setting squelch too low. That will make the scanner waste time trying to parse bits out of static before giving up and moving on. If squelch is set appropriately, dwell time on a site will be 1-2 seconds max, depending on data received from the control channel.
racing1
I'm having a similar issue except it seems to take longer for the scanner to ID Scan HB between talkgroups. Any way to improve this? My squelch is default @ 2. All other settings are also default.
Sent from my SM-G965U using Tapatalk
phask
zanesville
On a tunked system squelch can be zero. Try it.
UPMan
In Memoriam
Arlington, TX
Not if you want it to scan properly. Setting to zero can result in it taking a long time to find the control channel and can also cause it to hang after comms end (if end code is not detected). Squelch should always be set high enough to be above the noise floor.
jonwienke
VA
The only time that's a good idea is if you're holding on a single site with a weak signal. If you're scanning multiple sites it causes the scanner to hold on sites excessively long times.
bearcatman56
ewing twp. nj
I'm having problems with the sds100 I've pushed the button couple of times to hold it on the site now I hit the site button to let it go and it won't up top it says it's a site hold what is a site hold?
racing1
Site hold means it will stay on that site all the time.
