ARC536: SDS100 with ARC536PRO Virtual- What is the meter for (upper left hand)
ekim223
Crawford County PA
SDS100 with ARC536PRO Virtual- What is the meter for (upper left hand) corner of the Virtual screen?
N9JIG
Sheriff
Moderator
Far NW Valley
It shows what the radio reports. The radio is not calibrated so the signal strength indication is often sporadic. The bar graph has only 5 bars available so is usually more steady than a virtual meter like this.
Ubbe
Stockholm, Sweden
erratic response and inconsistent levels
If you enable a field in the scanners display to show dBm signal values it should be the same value that ARC uses to drive its signal strength meter. If it differs, then it might be a USB communication error, some data are compromised that also could affect other data that ARC needs for its virtual display. No other issues using ARC?
/Ubbe
ekim223
Crawford County PA
/Ubbe
After enabling the values you suggested, the signal meter is acting as expected. Thank you
