SDS200 3-Pin Power Connector Type
ben_r_
Sacramento, CA
Anyone know the type of connector the SDS200 uses for the 3-pin power connector in the rear of the unit? I'd love to be able to make my own custom cabling from that connection to some Anderson PowerPoles.
N9JIG
Sheriff
Moderator
Far NW Valley
I don't know the name but the power cable should have come with the radio. If you no longer have it replacements are available at Uniden Power Cord | Scanner Master
The orange wire is used to control the dimming on the display lighting, it is meant to connect to the interior lighting of your vehicle and dim the display as you dim your interior lights. If you leave this disconnected the radio will just use its own dimmer control (pressing the volume knob).
KevinC
The big K
Super Moderator
I'm everywhere Focker!
I believe the orange wire connects to the headlight switch and will dim the display when the headlights are turned on.
fxdscon
¯\_(ツ)_/¯
Yes, that's how Uniden describes the installation. This is from page 17 of the 2018 edition of the SDS200 owner's manual, but for some reason it's not mentioned in the 2019 edition of the manual:
Connecting DC Cable with Orange Wire
Connect this cable to the vehicle’s electric system that receives power when you turn on your
headlights. Now your scanner’s display will automatically dim when you turn on the headlights.
ben_r_
Sacramento, CA
Yea so far that's all I can seem to find, replacement cables. I was hoping to be able to make my own custom length runs with no inline fuse (for home use) if I could figure out that cable connector type. The one you linked to is $22 shipped, which is a bit more than I really want to spend on a connector, couple of fuses and wire.
donc13
Grand Junction, CO
It's a Uniden standard 12v power plug, it's identical to the 12v plug used by my Uniden CB.
Not having a fuse in a 12v line is not an intelligent practice.
a417
It's a Uniden standard molex-style connector (and is likely not going to be in a standard Molex catalog, or have a P/N that you can find an equivalent for), so there might not be the supply or demand out there to just buy a plug head and make your own. I see them all over the ebay for similar prices. You could always just find the female molex pins and shave down a more common Molex head to fit with an exacto knife, something I have done before. If you're not using the headlight dimming feature (which it sounds like you won't be at home), you could skip that pin and that makes dealing with that weird offset a bit easier.
I look at it this way, $22 for an inline fuse holder (always a good idea on every device) pre-wired to an odd-ball connector is a good deal.
ben_r_
Sacramento, CA
An inline fuse is not an issue for my use case. The cable I was hoping to make will be run to a PowerPole distribution block that has built in fuses, all of which will be powered by an Astron linear power supply. So, no need for an inline fuse. Could it hurt? No. But certainly not needed or useful. In fact it probably just adds a point of failure.
ben_r_
Sacramento, CA
Yea I figured it was some odd variant of a molex connector, was just hoping to find the one. Thanks for the advice.
nessnet
Eastside of Lake WA
Go to Digikey (or?) and do some research on 3 pin Molex connectors (and the pins needed).
It is extremely doubtful Uniden used a custom Molex connector.
I'm almost certain that with enough digging, DigiKey (whomever you choose) will have the exact same one
fxdscon
¯\_(ツ)_/¯
Maybe this....
nessnet
Eastside of Lake WA
garys
Texas
All of the ones I've seen for CB radios have two wires. The only application I've seen with three are for the Uniden scanners with headlight control of the display lighting level.
We've been using "Molex" as a more or less generic term in this thread. Uniden likely won't tell us who makes it, so I guess that's a good enough term. As you note above, that three pin connector isn't Molex, but it sure looks like it will fit in the Uniden scanners. The pin spacing would likely be the only question.
At the price on Ebay, I might buy one just to make a spare. Ironically, the shipping is more than the cost of the part.
Do the ones for CB have all 3 wires or just 2 wires?
lynnsnyder1968
Actually it's a point of PROTECTION.
ben_r_
Sacramento, CA
FWIW I shot an email to Uniden, we'll see what they come back with, if they do at all.
In the mean time I might just pick up one of these setups and just cut the cigarette lighter end off (LINK). That's as cheap as I've found so far.
