SDS200 Antenna Question
uavpilotmk
Atlanta
I recently purchased a SDS200 and love it.
I've been using it with the extendable antenna that was in the box and it works good.
What difference will I see going to a Diamond Super Discone Antenna?
I plan on mounting it on a fiberglass pole I have my weather station mounted on the very top.View attachment 78286View attachment 78286
I'm sure this is a stupid question but all of this is new to me.
Thanks for your time Mike.
TailGator911
Silent Key/KF4ANC
Fairborn, OH
Well, you can't go wrong with a Diamond discone, and putting it on a pole outside is a great idea. Your reception will improve significantly better than any rubber duck. I use a Diamond discone and get great reception, some systems almost 100 mi away. You have the right idea!
jonwienke
More Info Coming Soon!
VA
A discone is a good scanner antenna because it has a good response over a wide frequency range. Getting it up high will help reception tremendously. Just make sure you use good coax like LMR-400.
sparklehorse
Portland, Oregon
Does your fiberglass pole have guy lines for stability? I can’t tell from the pics you posted. If not, you’ll want ‘em! A discone is not exactly a small antenna, and it has some weight to it. Personally I would only mount one on a metal mast, and would research proper grounding and lightning protection. But for sure an outdoor discone is going to broaden your horizons in terms of what you‘re able to receive.
