SDS200 DID anyone purchase the gps dongle from unidenscanners.com
stprovost
rockford, MI
I received mine with no directions on the ccnnection to the scanner and what settings do I do on the sds200?
any help would be appreciated.
stprovost
nessnet
Eastside of Lake WA
Jon monitors here - (?)
Under location control, "Set Your Location" / Set Up GPS / Set Serial Port, try 9600.
A 200 should probably be using 9600.
If that doesn't work, try 4800.
choochwooks
carlsbad
stprovost
yes I did not receive any directions as well ... I am not thrilled with it either/ really does nothing for me and honestly doesnt function the way that it was portrayed
nessnet
Eastside of Lake WA
Please elaborate.
The functionality is 100% dependent on how you have it set up - (how much effort you put into it).
For example: My 100(s) and 200 switch what is being monitored as I cross state / county / city / even reservation boundaries - wherever I go in 2 states. Very slick.
radiomanj1
You guys make it so simple
Yet how do you know the GPS is RX
i have location in all lists to 0 range
I customize the screen for the Lat & Lon
shows nothing except NO GPS
so it seems some of us are so clue less, start again guys
1 charge the batteries, 2 turn unit on , 3 find the full data base, 4 plug in the GPS..........
plug and pray
nessnet
Eastside of Lake WA
plug and pray
In your detailed screen(s), set a field up to be "GPS". This will give you an icon that then tells if you have the GPS 'talking' to the radio.
If yes, then it is a matter of no signal lock. Wait a bit and/or get the GPS somewhere where it has an unobstructed sky view. It takes a bit to first download the data.
If no GPS icon (after setting it up in the detail(s) screen(s), you have an issue with the GPS communication with the radio. You need to check the baud rate in location control and change it to either 4800 or 9600. One should work.
Worst case scenario is the physical connection between the GPS and the radio.
