I have just moved into a new home and recently connected my two (2) SDS200 scanners. They are hardwired into a network node on my mesh network (Deco). I am trying to set up a new database for the local simulcast system using ProScan, but the scanners will not communicate with the software. I checked the LAN settings in the scanner menu and both have DHCP assigned IP addresses and I can ping them both from the PC that I have ProScan on. I am not behind CGNAT and I have verified the IP addresses and subnet mask for both scanners.
I tried communicating with both of them using Sentinel with the same result. I'm out of ideas. Everything worked fine on my previous network so I have to believe it's something to do with the new LAN.
Any ideas from the group ?
Thanks - Brad - WA9BD
