SDS200 nxdn
citione
SDS200 Vermilion, Ohio police dispatch is listed as nxdn. I have the upgrade but is coming up as NFM. How do I change that ?
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Welcome to the RR forums:
If you used Uniden Sentinel for programming (much much easier than programming by hand) it should import the data directly from the RRDB as an NXDN conventional object & you shouldn't have to change any mode settings but it sounds to me like maybe you're programming by hand? Menu > Manage Favorites (E)> {Select Favorites List] (E) > Review / Edit System (E) > [Select System] (E) > Edit Department (E) > [Select Department] (E) Edit Channel (E)> [Select Channel] (E) > Set Audio Type (E) > DIgital Only (E) > SET NEXEDGE RAN > [Choose RAN code] (E) Press menu repeatedly until scanner returns to scan mode
155.8875159.0375WPYR894RM5 RANVERMILLION PDISPVermillion Police DispatchNXDNLaw Dispatch
