Seaside Finds 2018
mondaro
Harrison, New Jersey
2018 List
Boat US Marine Channel 5 operating with a DPL of 565.
160.175 Color Code 1 - Active in the Toms River Area, unknown Biz.
Will add more as we get them.
Robt
mondaro
Casino Pier Channel 15: 151.0050 or 151.0500 Possible DCS of 245
From operations main channel they say either switch, switch up or go to Channel 15
Eli try to confirm this I think you may be closer to the Casino Contol Point especially the DCS code -
Misc I picked up at Casino Pier -
151.115 DCS 036
159.125 DCS 074
153.185 TPL 210.7
152.335 TPL 210.7
Seaside Park Beach Attendants: 150.805 DCS 223 - CONFIRMED
ID as Streets, Avenues & bays
Seaside Park Beach Patrol on 155.1750 TPL 107.2
ID as Stands -
Breakwater Beach also using 151.7450 DCS 244 as part of there Operations.
Confirmed -
Breakwater beach when they say switch or switch up its 151.865 DCS 032
form they main ops channel which is 151.7500 DCS 503 -
Another Active channel is 159.945 DCS 466 for Breakwater beach
More as I get them -
Cheer's !!
mondaro
I was able to confirm Casino Pier Channel 15 as 151.0050 DCS 245 - they use this as there " Secure "
Channel - seems like low power as well -
665_NJ
New Jersey
More Info please...
From operations main channel they say either switch, switch up or go to Channel 15 - Added to DB good pick up
Need some more info on these..what type of comms etc if possible
151.115 DCS 036, 159.125 DCS 074, 153.185 TPL 210.7, 152.335 TPL 210.7
ID as Streets, Avenues & bays - Added to DB good pick up
ID as Stands - As listed in DB - No change here.
Breakwater Beach also using 151.7450 DCS 244 as part of there Operations. Confirmed - - Added to DB good pick up
151.865 DCS 032
from their main ops channel which is 151.7500 (151.7450) DCS 503 -
151.7450 and 151.7500 are too close (+/- .005 MHz) most likely it s the licensed freq of 151.7450 under WPFL894
So, are there 2 DPLs being used on this frequency by the licensee
DCS 244 and DCS 503 - Need clarification here also.
Cheer's !!
Tony, I Need more info here if possible, see my remarks in RED within your above quote.
Thanks.
elias1988
West Creek,NJ
Picking up on 155.9325 with DPL 223,probably another beach channel. Getting some static with it while 150.805 is loud and clear.
665_NJ
New Jersey
Seaside Finds
Elias.
The 155.9325 Freq - coming over as Base / Mobile or Repeater?
(This freq is licensed as a FB 2)
The 150.8050 Freq - coming over as Base / Mobile or Repeater?
(This freq is licensed as mobile)
The could have also switched things around???
665_NJ
New Jersey
Seaside finds ...
One sided communications only with static on 155.9325,150.805 seems to be on a repeater.
Does 155.9325 traffic repeat on 150.8050? Where on 150.8050 your hearing both sides of the traffic. Or is the traffic different on both frequencies?
Thanks again in advance...
665_NJ
New Jersey
Ellis thanks for monitoring and checking this data out, since your there. While I up here in NE part of the state. One more item please, can you check if 150.77500 KB94184 M 107.2 PL Beach Maintenance (Expired Lic) for Seaside Park is still in use?
elias1988
West Creek,NJ
I’ll see what I can do as I’ve never heard that channel active,I believe public works is responsible for beach maintenance. For 150.805 the correct/official naming is Beach Control.
