Seattle Question
Bonney Lake
Uniden Bearcat programing with Freescan. I am picking up more than I want. I create a site for just Seattle PD which has 4 main dispatch channels, but then I end up hearing all kinds of other conversations. I am guessing that I am picking up everything on the "frequencies" that is Seattle PD. How do I narrow down my programing to only the HEX ID of the Talk groups I want?
nessnet
What month is it?
1st - you want to have at least have the tac channels also.
2nd - PSERN is trunking (you mention talk groups in your last sentence, so I assume you know this)
I don't do Freescan, so I have no advice there, but can't you edit in Freescan and just have the TGs you want?
Seattle Police
DEC HEX Mode Alpha TagDescriptionTag
2030cbTSPD Disp. WestDispatch WestLaw Dispatch
2050cdTSPD Disp. NorthDispatch NorthLaw Dispatch
2070cfTSPD Disp SouthDispatch SouthLaw Dispatch
2090d1TSPD Disp EastDispatch EastLaw Dispatch
2130d5TSPD DATAWants & WarrantsLaw Tac
2010c9TSPD ATGAnnouncementsLaw Tac
2150d7TSPD Tac 1Tactical 1Law Tac
2170d9TSPD Tac 2Tactical 2Law Tac
2190dbTSPD Tac 3Tactical 3Law Tac
2210ddTSPD Tac 4Tactical 4Law Tac
2230dfTSPD Event 1Event 1Law Talk
2250e1TSPD EmergEmergency Button Talk GroupLaw Tac
2270e3TSPD Tac ETactical EastLaw Tac
2290e5TSPD Tac STactical SouthLaw Tac
2310e7TSPD Tac NTactical NorthLaw Tac
2330e9TSPD Tac WTactical WestLaw Tac
2350ebTSPD INV TAC1Investigative Tactical 1Law Tac
2370edTSPD INV TAC2Investigative Tactical 2Law Tac
2390efTSPD CTR 1Center 1Law Talk
2410f1TSPD CRT 2Center 2Law Talk
2430f3TSPD Cmnd 1Command 1Law Talk
2450f5TSPD Cmnd 2Command 2Law Talk
2470f7TSPD Cmnd 3Command 3Law Talk
2490f9TSPD Cmnd 4Command 4Law Talk
2510fbTSPD Cmnd 5Command 5Law Talk
2530fdTSPD HarborHarbor PatrolLaw Tac
2550ffTSPD ITSInformation Technology SupportLaw Tac
257101TSPD Narc 2Narcotics 2Law Tac
259103TSPD Narc 3Narcotics 3Law Tac
261105TSPD NTFNarcotics Task ForceLaw Talk
263107TSPD VICE 1Vice 1Law Talk
265109TSPD VICE 2Vice 2Law Talk
26710bTSPD CIS 1Criminal Investigation Services 1Law Talk
26910dTSPD CIS 2Criminal Investigation Services 2Law Talk
27110fTSPD EM RESP1Emergency Response Team 1Law Talk
273111TSPD EM RESP2Emergency Response Team 2Law Talk
275113TSPD HOS N1Hostage Negotiator 1Law Tac
277115TSPD HOS N2Hostage Negotiator 2Law Tac
279117TSPD INTERNALInternal InvestigationLaw Tac
281119TSPD Trng 1Training 1Law Tac
28311bTSPD Trng 2Training 2Law Tac
28511dTSPD Trng 3Training 3Law Tac
28711fTSPD Trng 4Training 4Law Tac
289121TSPD Trng 5Training 5Law Tac
291123TSPD Trng 6Training 6Law Tac
29912bTSPD Cmnd 6Command 6Law Talk
34915dTCourt SecMunicipal Court SecurityLaw Tac
1557615TSPD T-Mob FieldT-Mobile Field OperationsLaw Tac
2801af1TSPD AS NARCNarcoticsLaw Talk
2803af3TSPD DVICE1Vice 1 - DigitalLaw Talk
2805af5TSPD DVICE2Vice 2- DigitalLaw Talk
2807af7TESPD Enc 44912EncryptedLaw Tac
2811afbTSPD DTAC1Tactical 1 - DigitalLaw Talk
2813afdTSPD DTAC2Tactical 2 - DigitalLaw Talk
2815affTESPD Enc 45040EncryptedLaw Tac
2817b01TESPD Enc 45072EncryptedLaw Tac
2821b05TESPD Enc 45136Encrypted
devicelab
Radio N.E.R.D
WA (USA)
Create a P25 Trunk System with only Site 125. You only need 854.2875 Mhz but it doesn't hurt to have the alternate control channels. (The frequencies in RED.) You can also add Site 126, 127 but you may not need them. From my monitoring there's nothing specific to those sites. Site 125 should get you all of SPD. The other sites may work better for you depending on your location.
Nessie gave a partial list of SPD TGIDs. Create a "group" and enter the above list into the scanner. There are a few others and you can ignore the ENC groups as you won't be able to hear anything anyway. The scanner won't stop on those either.
Also, Freescan defaults to ID SEARCH mode, IIRC. So you'll want to change that to ID SCAN if you ONLY want to hear the groups you've programmed.
Freescan uses the decimal TGID numbers -- not Hex.
Oh and you'll want to set the QUICK KEY to say "1" for the PSERN system -- and when the scanner starts scanning -- click 2, 3, 4, thru 0 to disable the other banks. Then you'll only be scanning the trunk system you've programmed.
nessnet
What month is it?
the op didn't use the model just said brand, anyways could it be a simulcast issue where he is at? With my antenna in the window and so forth Seattle PD comes out just fine.
The OP: "I am picking up more than I want."
So, - this was more of a programming inquiry.
Asking how to only monitor selected SPD TGs.
It was never clear, (or I missed it), if "more than I want" was all of PSERN, or all of SPD, (or ??).
Bonney Lake
Thanks to all who replied. I got it working. I think the biggest help to me was was switching to "ID Scan" on Freescan. Someone Said that Freescan defaults to (something) other than ID Scan. Once I switched over to that I was good to go. The model is a BCD325P2.
Now, it seems there's sun spots, solar flares, interference of some sort going on. Been really quiet that past few days.
Anyways, thanks again for everyone's input.
hachiyr
Seattle, Wa
I have a BC325P2 and when I was working at Metro Transit I used it all the time, now I am retired a few years and took interest in my scanner again. I still receive Seattle transit but can no longer receive Seattle Police, or Fire. Can someone tell me if I need to reprogram my 325P2 or what The last time I programed this scanner I just plugged it into the soft ware provided by radiofrference and it was done. I have no idea how I did that so is there any hope for me.
Any help would be great
nessnet
What month is it?
ALL Puget Sound radio traffic is now on PSERN, a P25II system.
The old system has been decommissioned.
If you are trying to listen to the old system, it is no longer operational.
You need to program this:
Puget Sound Emergency Radio Network (PSERN) Trunking System, Seattle, Washington
hachiyr
Seattle, Wa
nessnet
What month is it?
I want to thank you so much for showing how to program (PSERN) it took me a few tries but it now works, I have been trying for a long time, thanks again!!
Not sure if I showed you how to program it... I pointed you in the right direction, :) - but glad I could help.
I was one of the people that documented the changeover from KCERS with banks of RTL-SDRs and then helped determine the new PSERN talkgroups and helped get them submitted to the database. So, I am very familiar with PSERN...
hachiyr
Seattle, Wa
I set up two groups one for SPD and one for SFD. now when I scan it only scans the two groups. do you know how I can go from the two groups to an open scan? Also I have not been able to set a priority channel in P25 am I doing something wrong? any information would be helpful. Sorry for being so needy for information but if you don't mind it would be very helpful.
nessnet
What month is it?
hachiyr
Seattle, Wa
Note: I am not that familiar with the 325P2, so here is a resource for you....
Easier to Read BCD325P2 Digital Scanner Manual
Do you have quick keys set up?
Is location control on - and the location info correct for all of your departments?
(If you set up your favorites using Sentinel, the location info populates automatically).
Priority in trunking is different than conventional.
Mr. nessnet I just want to thank you again for all your help. If it weren't for you I would have this expensive scanner and still not being able to use it. Thanks for answering E mail.
nessnet
What month is it?
(y)
This what we are here for.
The only things we ask for here is to give us as much information as possible when asking something, to help us help you.
And, to familiarize yourself with the RR forum's search function and use it.
Many (most) questions have been answered in the past and a quick search will most likely get you what you need. Of course, if you can't find an answer, ask away.
