Securitas in Sun City Hilton Head
Smithbrother
Bluffton
Hi Everyone,
I'm new to this and don't understand many terms, but I live in a large gated community called Sun City Hilton Head. Part of it is in Jasper County and Part is in Bluffton County. We are patrolled by private security called Securitas. They have a security chief, a dispatch center, and many vehicles. They keep everything that happens in the community hush hush. They refuse to let anyone examine their dispatch call sheet, and all incidents are sent to the HOA Board, and they decide what is released and what isn't. I'm looking for a way to monitor their radio traffic. I don't know if it's a trunked system, a private license or what they use for radios. I'm sure there are high end scanners that can search for frequencies and I was also interested in figuring out how to monitor the local police department and Sheriffs transmissions. I'm a retired cop and just sit around most days and there are always sirens everywhere.
Can anyone help me identify the frequencies they are on?
Tell me what equipment I will need to intercept the transmissions and give me any help in setting up a listening station.
Thanks,
Dave
tvengr
Well Known Member
Baltimore County, MD
Welcome to the Radio Reference forums! I would be happy to help search for it, but the FCC database seems to be unavailable due to the government shutdown. I believe you meant to say Jasper and Beaufort Counties. I will continue to check when the FCC database becomes available again. In the meantime, hopefully, a member in your area may be able to provide the info you need.
Wnqk784
Usually the security company that you are referring to runs on UHF that may or may not be digital and as far as law enforcement they are on the pal 800 and encrypted but you should be able to hear fire and EMS and the best scanner to use is the SDS 100 or 200 by uniden
Whiskey3JMC
Resident Numbskull
Simulcastylvania, TE
Welcome to the RR forums. Check the license linked below for activity. I wouldn't rule out DMR as a possibility, although not explicitly listed in the license emissions so be sure to use a receiver that supports it. Ops are simplex. Don't forget to submit your confirmed findings to the RRDB
See Beaufort County (there's no Bluffton County) and Jasper County talkgroups on Palmetto 800. Mode "D" talkgroups can be monitored. Mode "DE" talkgroups are fully encrypted and cannot be monitored by a scanner. Jasper County sheriff is fully encrypted. Bluffton (town) is between two sites of the Beaufort County Simulcast so I'd recommend picking up a Uniden SDS100 (or SDS200) to compensate for simulcast distortion you'll likely face with any other scanner. Though I'm also seeing a single fill-in site, Bluffton which may carry traffic of interest to you where the aforementioned simulcast distortion wouldn't be an issue
brian
DB Administrator
South Carolina
As others have mentioned, law enforcement in both Beaufort County (including Bluffton PD) and Jasper County are encrypted, which means their radio traffic cannot be monitored. You can monitor other emergency services (Beaufort County Fire Department dispatch and some operations are in the clear, EMS dispatch is typically encrypted) and other county services.
As for your local security service, you would have to do some sleuthing. The license that Whiskey linked to above is a possibility, but there are no repeaters listed on that license, only mobile (direct radio-to-radio) use. I would suspect that license is used for things like golf course maintenance or grounds maintenance in the development. There are no other licenses in a 3-mile radius of that license that would indicate a local radio system (repeater) in the development.
2 possibilities are more likely. The most likely scenario is that the security agency pays a radio system company to provide access and air time on a larger, shared trunked radio system. This is very common in the HHI area. Some of those systems are listed here, Beaufort County, South Carolina (SC) Trunked Systems with the MCA DMR system being the most likely, followed by Fleettalk and Charleston Wireless. There are likely some other system in use that aren't documented here. It's be a while since I've been in that area, and the radio monitoring landscape changes over time. You would have to get a scanner or an SDR set-up, learn how these radio systems operate, and do a good bit of monitoring to figure it out.
The other likely scenario is that they use an LTE-based Push-to-talk service on a commercial wireless service, like AT&T FirstNet. Sea Pines Security moved to a similar platform a few years ago, most likely for the same reasons (privacy) you mentioned in your original post. Unfortunately these systems cannot be passively monitored either.
One suggestion that could help narrow things down - get a picture of one of the security patrol vehicles, that specifically show the antennas on the outside of the vehicle. Even better, a picture of the console inside the car. This would show the radios in use and the antennas would indicate the frequency band in use. Post the pictures here and we can offer insight. It's possible that the security agency only uses portable radios (not using mobile radios in their vehicles), in which case getting a picture of the radio being carried by an officer would ne necessary. That's much more difficult to do while being discrete, unless you're friendly with one of the officers.
Good luck.
AB4BF
EM93cs
Everyone has given excellent advice! If you know the exact location of their P to P, base or repeater antenna, you could use antenna search.com to see what frequency they may be on.
tvengr
Well Known Member
Looks like the first listing under Beaufort County is what you're looking for.
Thanks! I missed seeing that in the database. Looks like Smithbrother needs a scanner capable of DMR trunking. The least expensive would be a Uniden BCD325P2 handheld or BCD996P2 base/mobile with the DMR upgrade. It is less expensive if you install the upgrade yourself directly from Uniden. Don't have a dealer do it. It would be better to go with a SDS100 handheld or SDS200 base/mobile with the DMR upgrade due to simulcast sites on the Palmetto 800 trunked system if OP wants to monitor fire and EMS. You may have problems with missed transmissions and garbled audio depending upon your location.
tvengr
Well Known Member
Did you ever get a DMR capable scanner? Did the Nor'easter hit you hard?
Smithbrother
Bluffton
I'm sadly very much out of touch with scanners. My first was a handheld RCA with 5 channels and I would have to go and buy the Crystal for each place I wanted to listen to. I then had a uniden programmable but it stopped getting things when they went digital but I could still pick up cell phone calls lol. I don't know what DMR is or the palmetto 800 trunked system. I was talking with one of their security guards that just works the gate and he said he did not know what channel they were on but knew that they could also monitor Jasper County and Beaufort County Sheriffs. Sorry I wish I knew more.
Smithbrother
Bluffton
Tvenger, after 34 years of Law Enforcement, I really don't care to listen to medical calls, fire, or police, just the Sun City Security. I guess with the group's help, I could find the least expensive option to do this through a handheld preferred. If I have to go the $700 route I will but would prefer the least expensive to get the job done. Simple to use without all the bells and whistles.
Smithbrother
Bluffton
Good luck.
Brian I will try to get a photo of their vehicle antenna and upload it
tvengr
Well Known Member
The least expensive scanner for Securitas would be the Uniden BCD325P2 handheld. You will need to add the DMR paid upgrade. It is less expensive to purchase the upgrade directly from Uniden and install it yourself. It will cost a lot more if the dealer does it. I can talk you through how to install the upgrade. If you purchase programming software, I will be happy to create a file for you to program the scanner. Unfortunately, the free FreeSCAN software does not support DMR or NXDN. You will need a trunking scanner to receive the Mobile Communications America DMR trunked system. The new Uniden BCD160DN handheld receives DMR out of the box but is for conventional frequencies only. It does not do trunking. I use Butel ARC XT Basic software to program my BCD325P2 and BCD996P2.
Mobile Communications America​
SiteNameCountyFreqs
002 (2)Bluffton, SCBeaufort, SC01 451.7125c02 452.400c03 452.225
Site Frequency Table​
LCNLSNFrequencyColor Code
011451.7125c12
012451.7125c12
023452.400c12
024452.400c12
035452.22512
036452.22512
Beaufort County, SC​
DEC Mode Alpha TagDescriptionTag
23TSunCity SecuritySun City SecuritySecurity
tvengr
Well Known Member
If you get the BCD325P2, here is an ARC XT file for programming Sun City Security into your scanner (First file). The system (Mobile Comm Amer) is on system quick key #1. Pressing 1 on the scanner keypad will toggle the system on and off. First, you need to install the driver for the scanner. The second attached file is the driver.
If you are having problems installing the drivers, see the following general instructions (some steps might differ slightly, depending on your specific operating system).
  1. Unzip the driver.
  2. Plug in the scanner using a USB cable.
  3. Right click on the Windows Launch icon (bottom left corner) and select "Device Manager."
  4. The device shows up with a yellow triangle.
  5. Right click on device and select "Update Driver Software."
  6. Select "Browse My Computer for Driver Software."
  7. Navigate to the folder where you have unzipped the above driver.
The driver installed and is assigned as: Uniden Serial Port (COMx)
(x) will be replaced with the actual port number.
Save the first attached zipped file to your computer and extract. Open the extracted file with ARC XT. Go to the Scanner tab and click on Upload to Scanner.
  • Mobile Comm Amer XT.zip
  • uniden_usbser.zip
wirr
Senior Member
Sorry to say, but the last time that I monitored MCA Con+ System 286 in early 2023, I did not notice any activity on TG 23 Sun City security (nor on TGs 24 and 29 thru 34). Another source indicates that the current active TGs on the Beaufort and/or Bluffton site are 25 35 39 49 67 and 84.
If security can monitor Beaufort and Jasper Counties, that suggests that they have 800 MHz radios, possibly on Palmetto.
tvengr
Well Known Member
Thank you very much for that info. If anyone has additional info on Sun City Security, please let us know.
