Seeking HKN6155 Programming Cable
PDAdminNX
I have some perfectly functional XTL5000 consolettes we use as backups that need a codeplug modification after a key change, and it seems the previous admin may never have had one of these. My Motorola vendor advised the HKN6155 cables were nigh impossible to locate. I'm aware of the homemade workarounds and can find a $300 option for a cable with the internal connector, but these are rack mounted and tearing them out anytime a codeplug change might be required is less than ideal. I hoped someone might have a spare lying about I could purchase from them before I explore those routes further. Could I be that lucky?
nokones
Sun City West, AZ
My mistake. For some reason, my tablet did not reflect that it was unavailable. Check with Bluemax49ers and if he doesn't have it, I would call twowayradioparts.com. Sometimes he may have the connector and ends laying around and he will make the cable for you. He is easy to work with.
wa8pyr
Staff member
Lead Database Admin
Ohio
I can't recall offhand if the XTL5000 consolette has USB pins on the accessory connector on the back, but if it does, make up a quickie USB programming cable for each radio, hook it up and leave it there (with the USB end hanging out the front of the rack) for future use. Short of finding the elusive HKN6155, that's probably your best option so you don't have to haul them out of the rack more than once.
I did this for several XTL5000 mobiles I had rack mounted and it saved me no end of headaches.
PDAdminNX
Oh, that's a good solution. I'll keep that in my pocket in case I can't find one. Thank you.
