Planning the installation of a drilled NMO mount in the centre of the roof of my 2019 RAV4 for a CB antenna.
Have a few questions with respect to NMO mounts, as there seems to be quite a bit of variation in them and I don't know the technical differences implied by the geometric differences.
Some NMO mounts are tiny, almost "stethoscope size", like the Larsen NMOHF and its variations: https://static.dxengineering.com/global/images/technicalarticles/lsn-nmokhfcxpl_lw.pdf
Motorola mounts are also very small:
Breedlove, on the other hand, has three models of NMO mounts, all with large, thick, discs:
So--what are those discs for?
What would make me want to choose between the two extremes of no disc at all vs. 4-1/2" disc?
Motorola 3080384M48 Antenna Roof Mount - Antenna Mounts - Antennas - Accessories - Two-Way Radio Equipment - Radioparts
<p>The Motorola 3080384M48 is a ¾ roof antenna mount with 17 ft. of RG58A/U cable, mini-UHF crimp.</p>
www.radioparts.com
- #503 needing 5/8" hole, has 2" disc 3/8" thick. NMO Roof Mount # 503
- #504 needing 5/8" hole, has 3" dia. disc 3/8" thick. NMO Roof Mount #504
- #505 hole dia. not given, has 4-1/2" disc but thickness not given. NMO 4 1/2 in. Puck w/ Ring Terminal # 505
