Sentinel: Sentinal Profiles
baybum
Howard County
Hello, I have multiple profiles. Whenever I change or add a favorites list in one, it applies that change to all.
I want to create a new profile that include different favorites lists and does not change the other profiles. What am I doing wrong?
This is an SDS 100 using Sentinal.
Thank you
fxdscon
¯\_(ツ)_/¯
Thank you
Favorites lists are common among all profiles. That's how Sentinel works.... if you search the forums you can find many posts on that. A favorite list added to one profile will be added to all profiles, and a favorite list deleted in a profile will be deleted in all profiles. You can control which favorites are sent to the scanner in a given profile by using the "Download" (on or off) setting in the "Scan Selection" tab in the profile editor.
RMason
Mississippi / Colorado
Thank you
Favorites Lists are common to all profiles. If you edit a Favorites List, the change will apply to all profiles. Deleting a Favorites List will delete it from all profiles. However, deleting a profile will not delete the lists associated with a profile.
baybum
Howard County
Got it, thank you
