Sentinel: Sentinel software on Wine/Linux Mint
thetfordjr
i am very limited. I have install Sentinel software in Linux mint Through Wine. Also wine tricks for net framewore for windows. The software opens but does not see the sd card. Anyone done this.
thank you
jasonhouk
Uniden AlphaMan
Uniden Representative
Marion, Ohio
  1. Connect the scanner via USB and choose Mass Storage mode (press E / Yes when prompted).
    Linux should auto-mount it (usually under /media/yourusername/XXXX-XXXX).
  2. Open a terminal and run:
    Bash
    winecfg
  3. Go to the Drives tab.
    Locate the drive letter that points to the scanner’s mount point.
  4. Click Show Advanced.
    Change the Type from “Autodetect” (or whatever it shows) to Floppy Disk.
  5. Click Apply → OK.
  6. Launch Sentinel again. It should now see the SD card.
Note: You often have to repeat the winecfg Floppy-Disk step each time you reconnect the scanner, because the mount point can change.
thetfordjr
    Bash
    winecfg
Thank you However still no seeing it. I see it in Linux. I can get into SS card by files in Linux. I run the winecfg command and follow your instructios still blank when choose read from scanner.
jasonhouk
Uniden AlphaMan
Marion, Ohio
After clicking Apply - OK you are restarting Sentinel?
