Setting Up ADP Encryption
2wayfreq
NM Kirk City
I have PPS 04-00-30 and Key utility 1.0.3.5. I'm trying to figure out how you change the encryption type to ADP. And, where do you type the 10 Character code in? Do, I need a keyloader or an .ekf file? In an APX, you can just type it in the box and the Key ID is 0000.
Forts
Mentor
Ontario, Canada
You enter the key variable and key ID into the encryption key utility. It should have come with a sample .ekf file that you will start off with (always struck me as odd that you just can't make a new file from within the key utility, but whatever...)
FishScan
There is a instruction .pdf in the zip file with the encryption utility.
