Setting up Frequency Scanner
DRL-XM43
Durham Region
I tried that link, but didn't know what to do with the files. Read my subsequent replies.
-It is a compressed 7-zip file
-unzip it with 7-zip (if you don't have it install it)
-unzipped there are 3 files
-the pdf are the instructions
-the instructions say
Installation
Copy 'SDRSharp.FrequencyScanner.dll' to your SDR# folder
Update the 'Plugins.xml' file with the following line (if it has not been done):
<add key="Frequency Scanner" value="SDRSharp.FrequencyScanner.FrequencyScannerPlugin,SDRSharp.FrequencyScanner" />
Done!
KG5RF
Installation
Done!
WinRAR did it for me.
Now I just have to figure out how to do the scan properly. I have it working, but it needs a bit of fine tuning for my purposes. I have been testing using the US FM Broadcast band (88 - 108 MHz). Sometimes the scan will stop on a detected frequency and never restart. I want it to stop on a detected frequency, log it, move on to the next detected frequency and then stop at the end of the band rather than recycling.
morfis
SET autoskip on and to a short time
...... and then stop at the end of the band rather than recycling.
That isn't an option but it should be easy enough to stop it yourself as you watch it run......a scan of a busy band like Broadcast FM should only take a few seconds.
KG5RF
Did that already. However, sometimes the scan still stops.
