I've been asked to configure a laptop to have multiple versions of the BK programming software. This is to support programming of all current (KNG/BKR) and legacy generations of the BK P25 radios.
I've been told that the latest version of RES does not actually support past generations well, and that people typically have multiple (older) laptops with either an older version of RES or the NEOVISION software to ensure they can do programming on all the radios in a deployment. This apparently comes up in rapid response scenarios, such as wildfire teams that come together from many parts of the country.
I've been told that updating the firmware of the radios, although an option in some cases, is not always allowed ( to avoid potential issues when the radio is returned to its home territory )
In other work I do, the typical approach is to either load multiple versions of the software into different "virtual machines" running under the the main operating system with an appropriate version of windows, or under the main operating system in different directories, if that is supported by the software.
I'm looking to see if others have run across this problem, and have come up with a workable method of supporting this, or if simply having multiple laptops with the different software is the current best approach.
I look forward to your thoughts!
