Setting up offset meaning
theborg
Hi
I want to make sure I am programming this correctly
when I have something like this
Frequency Offset Tone Call Location ST/PR Use VOIP Mi Dir
443.7000 +5 MHz 100.0 VE2RHH Montreal, Ecole Polytechnique QC OPEN 2.3 WNW
so the first frequency is the receiving frequency = 443.7000
when offset +5MHZ , does that mean the transmitting frequency = 448.7000 ?
thanks for your help.
I am not sure if standard is they start with receiving frequency and the offset means the transmit and then how to use offset to figure out exact transmit frequency
KK4JUG
GA
That's exactly what it means
robertmac
1. Attend classes to lead toward an amateur radio license. Very well explained.
2. RTFM as most explain this clear unless you are still using the Baofeng or TYT.
KK4JUG
GA
If you're programming a scanner, you won't care about the offset. You're concern will be the receive frequency. If you're programming a transceiver, be careful. Most of what will probably be available on the radio will either require a license or will be off limits.
