- Joined
- Nov 18, 2004
- Messages
- 890
- Reaction score
- 636
What size are the Havis consoles moving from left to right? and are they the Universal "C" Series, correct?
Jim
Jim
left is 14" the other 2 were a 24" that was damaged that I cut into 2 so 1 is 12" the other is 11"What size are the Havis consoles moving from left to right? and are they the Universal "C" Series, correct?
Jim
They are universal C. If you take the case of the 15X, 996P2 or 536hp the C-EB25-MMT-1P fits perfect
Doing good Joe...Come over any time<---- Jealous, but I know where to find you!
Hope all is well buddy!
Love your setup! What fittings are these? Cable TV connections? If so are you running different coax in to them and then using an adapter to make the connection? Thanks!Nice setup, wondering if your scanners have a color code (red = fire, blue = police, etc)? I just make them all different for the cool look. What I use the scanners for changes all the time
One is my 7550e UHF and the other is a friends. Everything is RX only I have a scanner antenna, 2 800mhz antennas, 1 UHF and 1 VHF antenna 60 feet up with 5 runs of 70 feet of LMR400. all go to multi couplers
I tested View attachment 107883and going from the antenna to the radio or with the no loss multi coupler= No difference
E-Bay $25
What coax do you use from the splitter to the radios ? I was going to get some LMR 200 for jumpers..Nice setup, wondering if your scanners have a color code (red = fire, blue = police, etc)? I just make them all different for the cool look. What I use the scanners for changes all the time
E-Bay $25
Got them on Ebay, this guy makes great cables you can go bigger but i found no difference since its less than 2 feet RG316 MINI UHF MALE to F MALE RF Cable FAST-SHIP LOT | eBayWhat coax do you use from the splitter to the radios ? I was going to get some LMR 200 for jumpers..
Thanks, I'll check him out !!!Got them on Ebay, this guy makes great cables you can go bigger but i found no difference since its less than 2 feet RG316 MINI UHF MALE to F MALE RF Cable FAST-SHIP LOT | eBay
Sorry - I see, the UHF MED channelsWhat do you listen to on the old Regency ACT-R-106?
Sort of...You can buy the dark gray plastic and put it on an older O5, found them from china $18 eachAll the newer dark gray O5 heads on the XTL's and one O7 on the APX
Are you running audio from your BCT15x's to your PC and if so how are you doing it? I'm trying to get audio to the PC for recording with Proscan but having a hard time. I have (2) 15x's connected with USB to Serial RS232 adapters but I'm guessing the adapter doesn't carry audio. I tried connecting from the recording jack on the 15x to the line in on the PC, but still no audio.Just finished remoting all my scanners 30 feet closer to the antenna. Still WIP but getting thereView attachment 116651
