Can one antenna be shared with several SDRs? If so what is the recommended connection? Appreciate the help and suggestions. Looks like I'm going to wind up with 3 or 4 SDRs to cover the necessary bandwidth. I found this on ebay: 6" SMA Female to Y type 2X SMA Male Splitter Combiner cable pigtail RG316 USA or 2 SMA Males to one BNC female would probably work better for me if it will work at all. Here is a picture of a diy home made 800MHz ground plane antenna that I made for a PRO-668/WS-1080 type scanner and believe it or not, works pretty good with the SDR. I also have the Tram antenna that I have wired to a female BNC.
