Shawnee trunked system help
fireant
Copland
856.4625 856.7375 857.4625* 857.7375 858.4625* 859.4625* 860.4625
these are the correct frequencies for shwne right? I had shwne in my pro 95 and was receiving them fine but changed the way the banks are put together and now cannot pick up shwnee at all cannot even find the control channel which I never had a problem with but I can pick up norman, ohp, edmond and all the others was thinking i may have the wrong frequencies was in shwnee over the weekend and did not hear anything on these frequencies any suggestions??
thanks
fireant
fireant
Copland
I made sure the bank is turned to mot mode and the frequency is also set to mot mode as well
fireant
foster_006
Springfield, MO
Did you say you were IN Shawnee? I'm sure that would make a big difference. It sounds like you missed placed the CC for Shawnee.
And can you explain
fireant
Copland
In bank 6 on my pro 95 I have shwnee programmed in with some conv. frequencies shwnee is in numbers 1-7 the bank is set to mot and so is the shwnee freq. this are the only trunked systems in this bank
fireant
foster_006
Springfield, MO
in conventional, try finding the CC that way. Manual through channels 1 through 7 in bank 6. You may have to adjust the sq.. If you can't find it, then more then likely you are out of area. I know from OKC when I'm mobile, I can't pick up shawnee until about I-40 and Choctaw...and east from there. Although on OHP, Shawnee's main police channel is patched to the OHP smartzone system on a talkgroup of 42544. It's too bad we can't...or at least I can't pick up Shawnee's TRS from here.
