shortwave - digital or USB
kg4rgn
New Kent, VA
Just tuning around the commercial AM bands ( 19m) and wsa having a hard time listening to a few distant stations and then decided to switch to SSB from AM.. The station now comes in loud and clear. Are SW stations now on SSB or is this a digital signal. Thanks...
kg4rgn
New Kent, VA
digital, AM or USB on 9.950 mhz
Listening to 9.955, in AM junk, but switch to USB and it is clear.....
what gives..........
kg4icg
Crazy Trucking Mechanic
Woodbridge, Va
Also don't forget that WWV Fort Collins, Co. is at 10.000 mhz broadcasting the time signal and also at 5, 15, and 20 mhz, in AM and is a powerfull transmitter and not all comercial broadcasters use AM. Some use sideband too. If you hear it better in ssb then in AM then chances are it's a ssb station.
R Collins
loumaag
Silent Key - Aug 2014
Katy, TX
This statement needs some revision. If a station is broadcasting in Single-Sideband, it is not intelligible if you attempt to receive it in AM. It just sounds a lot like Donald Duck. If the station is broadcasting in Double Sideband, Suppressed Carrier mode than indeed you probably will pick it up better on a communications receiver in SSB. (Either sideband.) You can also hear it on AM but, because of the bandwidth necessary for DSB, you will also have more noise, hence unless the signal is strong, or your receiver isn't very good then it will sound better in SSB mode than AM.
Al42
Long Island, NY, USA
This statement actually needs some revision.
If you listen to SSSC or DSSC on an AM receiver, it'll sound like Donald Duck. If you listen to a normal AM signal on SSB, the carrier and sideband ("selective") fading will be less noticable, or not noticable at all. (There's no carrier for the AM detector to work on in DSSC, so you're not going to understand it in AM unless the carrier suppression is poor.)
Al
W2PMX
kb2vxa
Banned
Point Pleasant Beach, N.J.
AM in SSB receive mode
Hi all,
Let's clear up this mess right now! A synchronous AM detector is the very best for reducing selective fades and gives clearer reception overall but very few receivers are equipped with one. Except for high end, rather pricy communications receivers you're SOL.
Second choice is listening in SSB mode, zero beat the carrier and select the sideband that gives best reception if you have splatter from an adjacent channel.
Methinks you guys should learn a bit of radio theory, it's sure helpful in understanding the monitoring hobby. I say this because even a brief tutorial on the spectral composition of an AM signal is a bit much for this post AND I expect you to do your own homework. (;->)
BTW, the original post said 19M, not 19mHz so it looks like you'll have to start out with the rock bottom basics. I don't mean to sound smug but I sure got rid of a lot of confusion by cracking the books in my beginning days of SWLing and DXing.
mancow
N.E. Kansas
I believe he meant the 19 meter band.
BTW, if it were digital how would you be hearing it without a digital decoder?
mancow
