BaoFeng_Blogger
Here's the situation...
I have a "Blue" BaoFeng BF-F9 V2+, ie:
https://www.amazon.com/dp/B00PTJ3LCG/ref=twister_B0192F343S?_encoding=UTF8&psc=1
It takes a standard "SMA-Female" threaded antenna connection. Unfortunately, the
unit came with the standard "Black" 5 3/4 inch rubber duckie.
https://www.amazon.com/Baofeng-Orig...ng Rubber Duckie Antennas&tag=viglink20662-20
I'm looking to up-grade the antenna that came with the unit. I thought, "if I'm going to
do so, why not track down a "Blue" one... if they're even made." It wasn't that hard,
via Google. I found this 14.9 inch "Blue" RH-771 SMA-Female Antenna @ $8.25
https://www.amazon.com/dp/B0728C99D...&qid=1534449915&sr=1-57&keywords=Ham+Antennas
After reading many posts here, there are many of you that lean toward antennas that
use BNC as the end connectors. Realizing this, I hunted some more and came up with
this "Blue" RH-771 BNC-Female Antenna @ $9.25.
https://www.amazon.com/NAGOYA-Repla...1533700608&sr=1-62&keywords=ham+radio+antenna
Knowing it has a "BNC-Female" end connection, I would also need to get a "SMA-Female
to BNC-Female" adapter for a additional $5.99
https://www.amazon.com/DGZZI-2-Pack...8&keywords=SMA-Female+to+BNC-Female+connector
Now I don't mind spending the extra money if it's going to give me a more easy, safe and
reliable way of being able to temporarily (until I get a base station), change from the 15"
whip to not only a mobile antenna, but a home rooftop too.
So... the question is: "What would you do... and in which direction would you go?
What Say You?
Once again... Thanks for taking the time to read and reply to this post.
73's to ya...
BaoFeng Blogger
What Say You?
73's to ya...
BaoFeng Blogger
