Which scanner?
The one you quoted the spec for. You made the statement and I'm just curious where you got your information.
Which scanner?
In my opinion, the impedance of the scanner/coax/antenna varies as a system over the wide range of frequencies that scanners are used for and the 50/75 ohm impedance of the cable is irrelevant.
It's supposed to vary around 50 not 75. You can play here to see what different degrees of mismatch can give:
Return loss and mismatch loss Calculator
The practical view is that, if you bother with a big, external antenna, then you probably need every bit of gain, and it doesn't look very productive to (partially) annihilate the antenna's gain with an impedance mismatch. Especially since the cable is not such an expensive component as to justify cutting some corners.
With a severe mismatch you may find that the whole thing is not any better than using the original rubber duckie antenna. So why bother at all.
Scanners do not transmit and your link is irrelevant.The 50/75 ohm question is so insignificant on receive that it is irrelevant. If we talk about transceivers,, that is a different story and most people should stick with 50 ohm cable.
So could you please elaborate on how impedance mismatch would affect transmission only?
We are discussing transmission line not antennas so that link isn't really relevant.There is an effect on receive but it is not significant.RG-6 has less loss than RG8X and RG11 has the same loss as RG8 @100MHz. Look at the loss chart at the bottom of this link:
Strong Signals - Co-ax Cable
From that link I would select LMR-400 as:
- it has matched impedance
- it has the lowest loss when compared to the mentioned cables
- it has the proper size to be fitted with a standard N connector
