Signatures in the wiki
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Recently I had a member that put a lot of stuff into the wiki for NY and Florida. Not really a problem, as the data looks fine - but that member signed each and every one of the changes.
As stated in our user guide, that's not a standard we follow. The wiki keeps track of every change made to an article, and where/when that change was made. Not only is this a standard here, most Wiki sites I know of also follow this rule.
The only time signatures are encouraged is if you use the talk pages.
Thanks and 73 Mike
DickH
As stated in our user guide, that's not a standard we follow. ...
Perhaps it should be a standard we follow. That's the big problem I have with WIKI. Not only can anyone put anything in there, but if I put something there I don't want someone else to change it. If there seems to be something wrong, I'll change it.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
That's unfortunately contrary to the spirit of the system, Dick. If I or someone else puts something there, it's quite possible that somewhere down the road, something is going to change. I would want to be able to have someone else change it if I'm not around for some reason.
All wikis - no matter what dialect they seem to use - have this same standard, at least the ones I've seen. If you want a 'private' webspace, this isn't it. Sorry 73 Mike
[edit] It's not completely private, but you are able to build your own little wiki page under your user ID. I guess that's about as close to 'private' as you would get in in the wiki-world.
