Silent CSP
samcken
SE Connecticut
Well, it finally dawned on me that something is going on. I have a PSR600, and always used the RR download in Win 500 to set up the CSP for me. It occurs to me that I am no longer hearing anything from CSP. It appears I am scanning the downloaded freq's, but nothing is coming across. Any suggestions on where to start?
Sam
pwscott
Chester County, PA
CSP
Would help to know where you're located, what Troop you usually listen to and what site/s you have programmed.....let us know the Control channel/s you're using and with what settings...
Placid1
NM
If you saved your previous "setup" load it back in and see if you get it again.
samcken
SE Connecticut
I'm in New London, usually listening to troop E. I'm getting absolutely nothing now. I tried downloading everything under the CSP in the RR database, and still get zilch. I still get hits on other freq's, but nothing on the downloaded CSP. I'll try using an old file, and maybe manually load the info (never done that before, time to dig out the manual!)
samcken
SE Connecticut
Well, it beats me! I double checked everything against the RR data, went through all the settings visible in Win500 and checked a few things in the PSR600 menu and found nothing. As a last resort, I reloaded my last updated file (which I had already loaded), and dont'cha know things are back to normal! I guess I loaded a 1 where I should have had a 0. Thanks for the help though!
gallagher073
Connecticut
Sam
I've had similar issues in the past with my 996XT. I resolved it by restoring to factory settings and re-programming it with a known good CSP file.
