simulcast A change?
azglocker18
OK, there is a 99% chance this is all my fault, but I cannot get phoenix PD on simulcast A anymore. I hadn't scanned phoenix in a while but when I tried the other day I had to change to simulcast B.
to be a little more clear, I can't even get a control freq on simulcast A! what did I do wrong? here's the control freqs I was using last year with no problems:
867.2125
867.9625
Thanks...Just need someone to slap some sense into me.
rwier
Phoenix, AZ
867.2125
867.9625
Phx PD Sim A very active, load and clear, no changes. What's your scanner and software?
azglocker18
I'm using my Pro-106. I'm in Mesa currently (but picking up Sim-B just fine...) but problem first came apparent when I was downtown today.
can't remember which is which, but version screen at boot shows the following
uP App Ver: RU1.9
DSP AppVer: RU1.4
DSP VocVer: RF1.0
azglocker18
I see being used. A blue alt, unusual.
yep just put that one in and getting control channel data.
while i'm here, I might as well ask. I have been using the roam mode, should I use this vs stationary?
rwier
Phoenix, AZ
I'll check my 500, it's handy, probably will be ok in yours, later.
rwier
Phoenix, AZ
I have multisite mode = Stationary
Also check cc's each pass = yes
I have both red cc's and both blue alt's, that's why mine didn't shut up, lol
azglocker18
sounds like I had been running on luck! I used to keep my scanner at work and never had any problems using only primary CCs. well, it works again! I'll try messing with setting more.
thanks all, this ain't a very active forum but you guys sure responded fast!
rwier
Phoenix, AZ
I'm only scannng
2 a & b
9 a & b
2, 9, 6, and 7 c
And it's non-stop, very active, up here in the far nw. I think I have my own air-unit, lol.
