When A & B were both active, PD and city services were on A, while FD and city services were on B, along with a few talkgroups from outside agencies, such as Glendale PD.
With B down for its transition to 700 MHz, A is currently doing double duty, carrying everything.
If you program in the control channel's that A is currently using, what you previously heard on B should be hearable again.
Keep in mind, that once B is fully back up and running, A will be taken offline, and everything that is currently on A will be switched to B for the duration of A's transition to 700 MHz.
Once that is done, PD should be going back to A, with FD on B, and city services on both, like it used to be.
John
Peoria
