Simulcast
trentbob
W3BUX- Bucks County, PA
HUH, I said what?🤣🤣🤣. I guess it depends on how you look at it "so as to RECEIVE what would otherwise be simulcast distortion".
KC1UA
Scan New England Janitor/Maintenance
Marstons Mills, Cape Cod, Massachusetts
It should be noted that in this particular situation, toasting a single slice will likely work regardless of the toaster being used. However, when the user attempts to toast numerous slices simultaneously, using the same toaster, the issue arises. Fortunately, SDT technology, despite its somewhat exorbitant price, is available to mitigate the issue.
(This thread will automatically self-destruct and be closed in 5, 4, 3, 2....)
samcken
SE Connecticut
I hesitate to reveal this since my experimentation and patent application are incomplete. Long before the publication of this thread I have been experimenting with wiring battery packs in series/parallel mode to power my 200. I have nearly perfected getting both waffles and microwaved chicken to perfection! Needing just a touch more power, I think maybe 1.21 gigawatts will do the trick! Off to the clock tower!
