Sinclair duplexer notch drifts
WRMD298
I have a spare Telewave TPRD-1586, six 8” cans that will do 100dB isolation at 400KHz and at 600KHz it’s got more isolation and only 1.2dB insertion loss. Plus it’s rated for 350w! But I don’t have any use for the Wacom, sorry.
Nice.. I have the TPRD-1556 but it's in service at the moment.. I don't think I have space for a TPRD-1586 in the space I have.. I'm not trying to get rid of the Wacom.. I would love to have more Wacom duplexers because I really like their capacitor/notch adjustment rods better than trimmer caps..
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Looking at the Q2220E it appears to be a wee little 4" cavity job. If so that's not going to work well on a 600KHz split and duplexers of that type are typically rated minimum 1.5MHz split. If you had four 6" Bp/Br cavities you can get reasonable isolation at 600KHz.
For VHF ham, I would never use a 4 cavity Res-Loc.
WRMD298
Please elaborate/explain why. I'm certainly not partial to it for any reason. It was just given to me free of charge (probably because it did have a problem). Why would you never use one of these?
kayn1n32008
Sector 001
Because 75dB is just not adequate isolation @600kHz separation for a 50w+ repeater. On VHF, in amateur service, or LMR service with less than 1.5MHz separation between receive and transmit, I would use no less than a 6 cavity duplexer. I've experienced desense, as a user, with only 4 cavity duplexers in ~500kHz frequency splits(I had seen the way the company I worked for, set up their repeaters.
I've tuned lots of BpBr Sinclair ResLoc duplexers, and I have never experienced the issue you are seeing. They are usually absolutely rock solid onced tuned with the proper gear. My only question is if this site is temperature controlled(I don't recall if thay was asked)
WRMD298
Yes, the site is climate controlled. Duplexer problem has been addressed and fixed due to two faulty trimmer caps. It's been running rock solid as you say for about a month now.
It has been said on this thread that 75 dB is "not adequate isolation at 600 KHz separation for a 50 watt repeater." What exactly dictates this? The purpose of the duplexer is to allow the transmitter and receiver to operate on the same antenna with optimally zero effect with each other. If I can run the power I intend to run and get, zero transmitter-to-receiver desense or degradation in performance when the transmitter kicks on, then it seems as if I certainly DO have enough isolation. What else could I possibly need? I would totally understand how I would need more isolation if I kicked the transmitter on and it desensed the receiver by 10 dB... but I don't have that issue, running the test into a good dummy load -AND- running the test into the site antenna.. all the same.
Doing some math here.. the duplexer has 75 dB of notch per side, giving 150 dB of total isolation between the two frequencies. The transmit power is 50 watts, which is +47 dBm. +47 dBm minus the 150 dB of isolation gives a -103 dBm result, meaning the receiver at 147.600 MHz for example will "see" the 147.000 MHz transmitter with a signal level of -103, or about 1.6 microvolts. Any decent receiver with a clean front end amplifier stage and especially a clean I.F. chain will certainly tolerate this amount of signal 600 KHz away without any degradation. This has been my experience anyway. Now, if you use two crappy mobile radios back-to-back (like a lot of so-called "repeaters" are made of these days) then no way..
I totally agree that a six-cavity, >100 dB rejection duplexer would certainly be needed if you're running a 250W power amp on the TX and a GaAsfeT preamp on the RX and a 600 KHz split.. yes, I agree that 75 dB would definitely fall short. No argument here. I'm just saying it's working for me, maybe my repeater TX is just super clean and I got lucky.
buddrousa
I am glad it works for you but let me ask you a question.
Which Doctor would you pick to do your Heart Bypass?
Doctor #1 that made a 80 on his test and charges $250,000.00
Doctor #2 that made a 100 on his test and charges $500,000.00
The standards you were given were the standards that Radio Shops use in picking and setting up hardware. You got lucky and it works for you but people that get paid or charge customers cannot afford to guess cheaper will always work. There are way too many variables at sites to just guess. But just remember you are the new user that came to a Hobby Site asking for help from Professionals.
WRMD298
Yes, I'm beginning to understand now.
kayn1n32008
Sector 001
Exactly, while a 4 cavity duplexer of decent design, and manufactuer can certainly work, it's not something I would do.
I am glad you figured out what the problem with the capacitors.
AM909
Radio/computer geek
SoCal
... Doing some math here.. the duplexer has 75 dB of notch per side, giving 150 dB of total isolation between the two frequencies. The transmit power is 50 watts, which is +47 dBm. +47 dBm minus the 150 dB of isolation gives a -103 dBm result, meaning the receiver at 147.600 MHz for example will "see" the 147.000 MHz transmitter with a signal level of -103, or about 1.6 microvolts. ...
Let's assume 2 dB insertion loss. 147.0 TX +47 dBm produces +45 dBm at the tee. If the receive cans in front of the receiver were notch-only and yielded -90 dB @ 147.0, you would get -45 dBm @ 147.0 into the receiver. The pass characteristic of these receive cans will help, though I can't immediately find a chart that's relevant to narrow splits like this to find out how much.
Don't forget about the transmitter noise at the receive freq, either. Let's say a decent -75 dBc, which gives -28 dBm @ 147.6 out of the TX, notched -90 dB by the TX cans' notch gives you -118 dBm (0.28 uV) on-channel at the tee (and close to it at the receiver), which is close to a modern receiver's 12 dB SINAD sensitivity. Hopefully your transmitter is cleaner than -75 dBc @ +/- 0.6 MHz, but I've seen some ...
