DSDPlus Single Receiver decoding not working
devicelab
Radio N.E.R.D
WA (USA)
For the record, I've tried this both with my Airspy Mini and a RTLSDR v3 dongle and both exhibit the same problem.
So I've configured both for R1 monitoring and both seem to start up fine. I can see FMP24 or FMPA working and centered on the frequency, etc. I kick off the 1R or 1RA batch file and all appears working. I can see audio being detected by dsdplus over port 20001 via the blue audio window. But that's it... I'm not getting any decode. Notta. Zip.
I went so far as to set my 1R/A files fixed for P25 only -- (I'm centered on a Phase 2 P25 control channel...) but that didn't help.
From what I've read, I shouldn't need anything configured in any of the support files, correct? (e.g. the .sites, .frequencies or .networks)
Oh I tried disabling my Win10 firewalls but that didn't help. I figured it wouldn't since I can see audio from the dsdplus monitor.
My DSD+ works fine using SDR# in the usual configuration.
Scratching my head...
cg
Connecticut
Since the issue is likely in your setup, posting your batch files would be quite helpful.
I would work on 1 setup at a time and get that working.
For P25 be sure your bandwidth it 12.5 or 9.5
chris
air-scan
Here is my start up batch file for RTL-SDR. Ignore the START commands and look at each line as if it is it's own configuration file. Follow that example.
START FMP24.exe -rc -i1 -o20001 -P0.0 -g24 -b12.5 -f851.1875
START DSDPlus.exe -r1 -e -T -E -Pwav -i20001 >>1R-log.txt
DRL-XM43
Durham Region
Single batch file - this works for me,
start FMP24 -i1 -o20002 -f452.2625 -b12.5 -P0 -q1 -g37.2 -_1 -wsl000.00
start DSDPlus -F1 -r1 -e -m1 -i20002 -OM NUL -_3
Then using the L (List feature) you are off to the races.... This one does clear FM/AM and all the digital.
devicelab
Radio N.E.R.D
WA (USA)
Yeah my batch files were fine. I finally figured it out. The polarity auto detect was disabled by default for whatever reason. As soon as I pressed "P" everything started piping thru and decoding. Geesh.
