Six Flags LTR
Hudson, MA.
Does Six Flags still use LTR or are they on a different system? (P25, NXDN, TRBO)
I have the LTR system in my radio but I'm not within range to verify if that system still works. Or if there are any updated TG's or ID's.
ecps92
Taxachusetts
IT has been ages since anyone has reliably reported on the former Riverside Park
However there was some recent FCC actions, for a local Radio Shop and the Lat/Lon was likely the Agawam site
cg
Connecticut
The system is fairly weak. I cannot hear traffic 11 miles away. I would be surprised if they were not using digital or at least planning to do so.
chris
W1KNE
Rooting out dumbasses since 2011.
Southern New England
When I lived in Agawam, I was only about 5 miles north of the park, and really couldn't hear it until you are south of 57. As others said it is very low level, and honestly, there isn't a ton of radio traffic unless it is really busy.
Hudson, MA.
Interesting. I'll have to listen to it when I go to the park some time.. Thanks for the info :) What else is undiscovered in this state..
W1KNE
There is a lot. While we have added a ton to the RRDB and SNE-Wiki, there are so many things that need to be identified and/or verified. The list for Massachusetts alone is quite large.
I find searching for new/unconfirmed users the most fun part of this hobby.
cg
Connecticut
Six Flags NE is using a 5 frequency LTR system under their own license. As expected the range is around 3-5 miles. No talkgroups ID'ed in the hour or so that I was monitoring (but I did hear that the Sno-Cone machine is not working well)
I posted the info on the Scan New England site in the WIKI.
Six Flags New England
chris
Hudson, MA.
Halloween and Summer peak season/special events
Try listening to the system when Halloween rolls around, or when they have a LOT of people, most often in the summer, try watching the Water Tech TGID (0-02-134) and Security
xplorer417
AGAWAM MASSACHUSETTS
hi all heres more information regards to six flags.the AGAWAM PD uses there DEPT issued radio and use the secondary ch for there also 155.7900 91.5 both rptr and simplex. simplex is referred to as ch 2 rptr reffered to as ch ch 3 is used for calling up to PD DISP.most of the time it's on direct six flags can call a PD officer on the ch to for special things fights or accidents in the area. of the park.
xplorer417
AGAWAM
if u have ur scanner setup for search try to see if there using other security chs I know when I worked there they said there was three security chs try to see what TG id thoses are thanks.
xplorer417
I found some updated TG IDS here it is as follows
1 0-02-150 is SECURITY 1/APD
2 0-02-151 SECURITY 2
3 0-02-111 is I believe parking / traffic they said traffic clear and the time
0-02-157 is tram
if we all get a good list together maybe someone can submit the new stuff so db can be updated I never once saw 0-02-121 at all I believe they changed the TG IDS a while ago
xplorer417
can anyone help and ID theses TG IDS looking to find loss prevention to update the loss prevention one also sounds like games is also on the system to / rides and warehouse /sales
0-02-158?
0-02-161?
0-02-162?
