Ski Sundown
Mork
Connecticut
Ski Sundown is operating on North Canaan Vol Amb frequency. Sundown is not apparently licensed for that frequency according to the FCC database.
Seems a bit strange.
CT
There is an active Lifestar call there as I type this for a 17 year old with a head injury.
Troop B is responding.
Edit. Cancelation due to weather.
Ground transfer via ambulance
n1chu
Farmington, Connecticut
Not strange at all. The Town of Farmington uses the FD frequency to keep track of the two AMR cars contracted for town coverage. I expect it’s an accepted practice provided all parties are in agreement.
cg
Connecticut
North Canaan doesn't respond to Ski Sundown in New Hartford.
cg
Connecticut
What frequency?
Ski patrol? Ski lift operations? Maintenance?
Mork
Connecticut
155.175 just as is listed on the RR DB
All of the operations are on this frequency licensed to North Canaan.
Ski Sundown does not appear to be using their own licensed frequencies.
155.17500 KOB360 BM67.0 PLSki SundownSki Sundown Ski Patrol FMN Busines
Mork
Connecticut
Litchfield Co New Hartford rr db
And I am monitoring the comms on 155.175 from New Hartford.
pro106import
Milford, Ct. perched high above Long Island Sound
On the RR page, it shows 155.175 as the input to the repeater on 159.4425. So it is probably used by both agencies. Different PL's. Also just FYI @a417 , when you look at RR database pages, make sure you have the "Input Frequencies" set to "Shown".
Mork
Connecticut
So if 155.175 is the input to a repeater, then this page has the input rather than the output listed, hence my confusion.
New Hartford
New Hartford is dispatched by LCD.
Frequency License Type Tone Alpha Tag Description Mode Tag
155.89500 KUG863 RM110.9 PLHighway / CoPublic Works / Constable Operations FMN Multi-Tac
155.29500 WPXV832 RM172 DPLNH EMERG MGMEmergency Mgmt FMN Emergency Ops
153.74000 KUG863 BMEmergency MaEmergency Management Region 5 FMN Emergency Ops
155.17500 KOB360 BM67.0 PLSki SundownSki Sundown Ski Patrol FMN Business
pro106import
New Hartford
FrequencyLicenseTypeToneAlpha TagDescriptionModeTag
155.89500KUG863RM110.9 PLHighway / CoPublic Works / Constable OperationsFMNMulti-Tac
155.29500WPXV832RM172 DPLNH EMERG MGMEmergency MgmtFMNEmergency Ops
153.74000KUG863BMEmergency MaEmergency Management Region 5FMNEmergency Ops
155.17500KOB360BM67.0 PLSki SundownSki Sundown Ski PatrolFMNBusiness
Yes I can see where the confusion came from now. That apparently is a mistake and that License link should not be there. It shouild be linked to the KNDY700 license.
Mork
Connecticut
The primary displayed freq should be the repeater output.
And still the KNDY780 license does not list the input nor output as licensed to Ski Sundown.
W1KNE
President, Scumbag Society of America.
Southern New England
Sorry about that. I should've deleted the entry under the New Hartford listing when the correct business listing was entered. It was deleted this morning.
The correct entry is listed under the business listings. The FCC license for Ski Sundown's 159.4425 repeater is WNIX697, and that has also been updated.
pro106import
W1KNE
I am monitoring 159.4425 and the input 155.175 carrier sq.
OK If you don't hear the repeater but only SKI AREA ops on 155.175, then submit it as a ticket and I'll update the listing.
Thanks.
Mork
Connecticut
Output copied on 159.4425 PL 67.0 confirmed (corrected PL typo)
a417
Yes, however enabling that doesn't give you the format that the OP posted. Enabling input freq gives you another column, and the bold typeface stays on the outout frequency. So as he copied and pasted it from an unlinked page, I was just trying to find where that was so the hivemind could get to the bottom of it.
As @W1KNE is on top of things, this matter should be sorted shortly. (y)
