Sky Wire performance TX/RX vs the antenna modeling programs
jjisella
3 years ago I put up a 600 ft horizontal loop up 53 ft for ham use. It's fed with ladder line to a 4:1 balun, then 4 feet of coax to 100w Icom rig with a Mat tuner. I never even cut it to resonance. I've run the simple model with EZNEC for 20m, indicates lobes are at quite a high angle. Not impressive as a DX antenna. In practice it's an awesome DX antenna. I'll spare the observations from pileup's and other circumstances where the performance of this loop has clearly been a lot better than the models predict. You can read in many places how people repeatedly say the same thing. Naturally everyone wants to think their antenna is a great performer... But after many contacts over 3 years I can honestly say this antenna is a superb DX performer. Has any else had similar experience and what opinions are out there of actual performance vs model predicted performance. 73 John K1KSC
devicelab
Radio N.E.R.D
WA (USA)
Do the numbers/plots match in MMANA-GAL? MMANA-GAL basic
It's a bit easier to use than EZNEC.
I punched a simple 50m square loop in up at ~50ft or so and it's going to act more like a yagi. So it'll be directional pointing forward of the feedpoint. The 'optimum' DX angle is 5 deg (so the experts say) and the square loop is more like 10-15 deg (with those numbers.)
If you feed it at the corner, then it'll be direction in the same manner.
