Sentinel: Small Favorites List on State-wide Trunked System
wgforster
Got a SDS200 and using Sentinel to program a fav list of just my immediate fire/police agencies. Specifically Ohio, Montgomery County and I want Centerville Police and Washington Township fire, that's it. They are on a statewide P25 system. I drill down through the county list in Sentinel and select just the Washington Township Fire and append to my FL. When I open this FL with the editor, Wash Township is there but so is every other county in Ohio. And each one of those counties has a list of freqs associated with it. So when I write this FL to the scanner and start scanning, I can see that the scanner is stepping through every county in the list. If I edit the FL and remove every county except the local police and fire that I'm interested in, and write it to the scanner, the scanner says Nothing To Scan. I know about making sure that the proper services are selected, that's not the problem. And yes, download and monitor are turned on. It seems as if because it is a statewide system you can't carve out just a couple agencies and discard all the other counties? I don't get it. My work around has been to use my zip location, set my range to zero and then scan and permanently avoid all the surrounding agencies that I don't want to monitor. I feel like I'm missing the obvious but I'm stumped. Any insight would be appreciated.
dave3825
Suffolk County NY
You can. Import the whole system into a favorites list. Delete or avoid all Departments you do not want. Then delete all sites that are nowhere near you. Set the system to Id Scan. Write to the scanner.
dave3825
Suffolk County NY
Import the whole system into a favorites list. Delete all sites except these two.
1 (1)005 (5)DaytonMontgomery772.85625773.13125773.48125774.05625774.55625c774.83125c851.0625
852.100853.575853.750855.2125856.2125856.7125857.2125
858.2125859.2125
4 (4)003 (3)Montgomery CountyMontgomery851.175851.325851.375851.575851.800851.850851.9375
852.0625852.1625852.325852.350852.550852.625852.650
853.200853.250853.325c853.500853.600c854.0375854.5375
854.6625856.4625856.9625857.9625858.8125858.9625859.0125
859.4625c859.9625c
Delete all Departments you have no interest in, except these two,
Montgomery County (57) Law Enforcement which has,
58160e330D57 CVPD DISPCenterville Police DispatchLaw Dispatch
58161e331D57 CVPD TAC1Centerville Police Tac 1Law Tac
Montgomery County (57) Fire/EMS/Hospitals which has,
58356e3f4D57 WTFDWashington Township Fire DispatchFire Dispatch
58358e3f6D57 WTFD CHATWashington Township Fire ChatterFire-Talk
Your two remaining Departments have a bunch of other talk groups in them. So either delete or set to avoid, anything in each Department you have no interest in.
If you set the system to Id Scan, it will only scan the tg's you have in your favorites list, which is what you want. Enable the proper service types.
Here is some info on Sentinel and the radio.
Sds100/200 E Z Read Scanner Manual
Sentinel E Z Read Software Manual
wgforster
Slowly coming up to speed on trunked systems. When I deleted all the stuff that I didn't want, I avoided the entire list of frequencies under Montgomery county but left the list of TGIDs. So the scanner had nothing to scan. I un-avoided Montgomery county and now seems to be working as I wanted. One baby step forward. Thanks for the help.
drdispatch
What's the frequency, Kenneth?
Fightin' River, Michigan
Glad you figured it out. First rule of programming a trunked system (or second, or at least in the top ten) is you've got to have at least one site programmed in order to hear any talkgroups.
ofd8001
Louisville, KY
As an alternative, you can set your Favorites List so that Location Control is On, being sure your zip code is set. Then the scanner will select the nearest sites.
Unfortunately this still has some of the nearby "stuff". You can Avoid undesired channels with the Avoid button or edit them in Sentinel.
JoeBearcat
Uniden Representative
AVOIDing Sites may be better, as when/if you ever update the list all deleted Sites will be re-imported. AVOIDing them will not change much on re-import. Make sure those two Sites are not avoided.
hiegtx
Dallas, TX
As long as you do not rename the system in Sentinel, it will not re-append the sites that you have deleted. So, you can append an additional department, but still no need to wade through a sea of previously deleted sites. (I tested this again, just now, to make sure this has not changed.)
If you modify the system's name, then your additional append (of a department) will append all of the sites as well as whatever Department(s) you chose, under the original systems name, in a new system.
