SmartRIB Questions
ronenp
Hi
Is SmartRIB Compatible with Reguler Rib If I want to program MTSX radios? MCS2000 Or Maxreac ?
Is the Serial Cable from the PC Com Port to the RIB same as for regular rib ?
Will it work with same program that the Regular rib Work with ?
Whatis the XP Switch doing ?
and what Can the SmartRib Do that regular Rib Cant ?
When I connect the serial cable from the regular rib to the smart rib the radio Make Reset ......
Any help would be appreciated
Thanks Forward
Ronen - 4Z4ZQ
Ronen Pinchooks (4Z4ZQ) WebSite
bezking
On the Road
The SmartRIB can be used to update the radio's firmware whereas the regular RIB can not.
ILMRadioMan
The road to no where.
To make a long story short:
The smartrib can do everything a regular rib can do (minus work on a 9v battery).
The RIB cannot do everything a smartrib can do.
ronenp
Thank you for the answer
What about the cable from the PC com port to the rib ?
is it same pin assignment as the regular rib or a diffrent pin order ?
Thanks Forward
Ronen - 4Z4ZQ
n7maq-1
Oregon
Thanks Forward
Ronen - 4Z4ZQ
The S-RIB uses a standard 9 pin serial cable, the RLN4008 takes a 15 pin so the cables from PC to RIB are not the same, the RIB to RADIO cables are the same.
