OP25 Smartzone SF
nokoa3116
I been trying to set up op25 multi_rx with a motorola type 2 smartzone for San Francisco which uses mostly analog voice channels . I used the sample file for smartnet, I tried to change it to my settings. The control channel is decoding. However, whenever it gets an active talkgroup OP25 crashes.
I was trying to use an Airspy mini, in addition to also try an additional rtl. I am not certain if i have things configured correctly
the log below shows that tgid 80 was active, 80 is digital encrypted, but this error comes up the same way for any other talkgroup
Code:
12/16/20 21:35:27.375078 [1] Initializing voice channel
python version detected: 2.7.17 (default, Sep 30 2020, 13:38:04)
[GCC 7.5.0]
12/16/20 21:35:27.438941 [0] SMARTNET OSW (0x42f3,G,0x308)
12/16/20 21:35:27.468246 [0] SMARTNET OSW (0x1bf7,G,0x340)
12/16/20 21:35:27.490387 [0] SMARTNET OSW (0x0058,G,0x060,853.412500)
12/16/20 21:35:27.512258 [0] SMARTNET OSW (0x3bf7,G,0x308)
12/16/20 21:35:27.535076 [0] SMARTNET OSW (0x13bf,G,0x340)
12/16/20 21:35:27.535259 [0] set tgid=80, status=0x8, srcaddr=-1
12/16/20 21:35:27.535328 [0] new tgid=80  prio 3
12/16/20 21:35:27.535521 [0] new freq=853.412500
Exception in thread Thread-2:
Traceback (most recent call last):
  File "/usr/lib/python2.7/threading.py", line 801, in __bootstrap_inner
    self.run()
  File "./multi_rx.py", line 815, in run
    self.callback(msg)
  File "/home/shahar/op25/op25/gr-op25_repeater/apps/tk_smartnet.py", line 135, in process_qmsg
    rx.scan_for_talkgroups(curr_time)
  File "/home/shahar/op25/op25/gr-op25_repeater/apps/tk_smartnet.py", line 795, in scan_for_talkgroups
    freq, tgid, src = self.find_talkgroup(curr_time, tgid=self.current_tgid)
  File "/home/shahar/op25/op25/gr-op25_repeater/apps/tk_smartnet.py", line 774, in find_talkgroup
    if active_tgid in self.skiplist:
AttributeError: 'voice_receiver' object has no attribute 'skiplist'
boatbod
Talbot Co, MD
Oops... the law of unintended consequences is alive and well! Please pull my most recent update and try again.
nokoa3116
Thank you! I will test this in a few days, I am not currently in range with this system.
