r9a9d9i9o9
- Joined
- Dec 12, 2010
- Messages
- 9
Wirelessly posted (Mozilla/5.0 (Linux; U; Android 2.2.1; en-us; Droid Build/FRG83D) AppleWebKit/533.1 (KHTML, like Gecko) Version/4.0 Mobile Safari/533.1)
Dear Home Patrol,
You looked so good at first glance when you said things like
"Listen to local emergency calls"
"Help sidestep accidents"
"Hone in on information"
"Quick and easy zip code based setup"
So I figured, yeah, let's go out.
On arrival, you kept asking me to connect you to a computer. Fine, easy enough and done.
When taking you for a spin, you spoke too softly. Your P25 is great but you needed to speak up! I wanted to hear you. You are the only one that always needs to speak at a minimum of 50% of your volume max and usually around 95% and still barely be heard.
When you are talking, its often about activity that I am not interested in. I know you don't know much better, its the circle based coordinates you have access to. For example, I didn't care about Illinois statewide freqs in Indianapolis, New York statewide freqs in Philadelphia, Mississippi statewide freqs in Birmingham, or Kansas statewide freqs in Lincoln Nebraska. You need to move away from using circles. Just like the centers of zip codes are available, you can get polygon based boundaries for all cities, towns, counties, and states in the US that GPS can recognize.
It would help if you could let me restrict to certain states or counties but you kept talking about profiles on the computer which defeats the purpose of saying you are easy. You should have an option in the menu to let me filter your blabbering a bit.
I also hated that when I locked in on an agency which often means county, you wouldn't scan trunked systems within the same county. Radioreference knows a trunked system is active in a certain county and so should you!
I really liked that you were completely on top of rebanded systems. I also liked that you can be updated weekly but for now you keep blabbering about areas I do not care about. If I need to use your Sentinel software I may as well use Win500 or Freescan.
You were very good when locked on statewide trunked systems with lots of towers. At $200 or $300 I could keep you around. Maybe $400 if you included a built in GPS chip instead of a NMEA hockey puck, kitchy cables, adaptors, and another power source requirement. You and your baggage are just too much for me to handle for $600.
I really had high hopes for you. If you have a sister or cousin, I could be tempted to go out with them but for now I need to end our relationship. Its just not working out.
Sincerely,
r9a9d9i9o9
Dear Home Patrol,
Sincerely,
r9a9d9i9o9
