Like to make some pointers to all on the KPG D1, D2, and D3 Licenses.
It is recommended by Kenwood, not to use a mac. Doing so you are at your own free will. This software is designed for Windows only.
That out of the way, Anyone who has a REGULAR COPY OF THE SOFTWARE, please make a note on what your machine ID is;
Open License management Client, go to SETUP, GENERAL, DEVICE ID. Click on copy, and save it to a text file where you can
pull it up should there EVER be a pc/laptop/HDD failure. This will be needed to send to Kenwood Tech Support.
You will also need the copy of your ORIGINAL EMAIL WITH THE LICENSE KEY.
In the event you have a hard drive or motherboard failure, contact your dealer that you purchased the software from.
They will contact KWD_TS with your information, to begin the license refresh. There is NO DEADLINE TIME ON THIS
PROCESS!
On the new HDD or PC, reinstall the KPT-300, D? and the KFL programs.
Once you have installed the KPT-300 (LMC) go into the setup, general, device ID, copy that number and submit to your dealer along
with the OLD Device ID, and the original email with the D software key.
Your dealer will contact you when all information has been submitted to Tech Support for refresh.
WIDE BAND LICENSE KEYS (authorized uses) Please understand this:
WIDE BAND KEYS WILL NOT BE REVIVED! PER KENWOOD.
If you think you are going to have a hdd failure or a motherboard going south,
open License Mgmt and CANCEL OUT THE LICENSE and export it off of that PC immediately.
If you lose it before you cancel the license, there is nothing that can be done to undo this.
You will have to re-purchase a wide band license. Even dealers have the same issue, they will
not renew a wide band license. One shot deal. Kenwood says buy a regular license and only
use the wide band when needed, otherwise turn it off, and put it away till you need it again.
Record your machine ID and save it somewhere whenever you update your pc or HDD.
Chow for now.
EFM
PROCESS!
Chow for now.
EFM
