BCD436HP/BCD536HP: Software question
BlueMoon2
Midlothian, VA
For those that program the 436hp/536hp and sds scanners for others using the uniden software, any tips on managing programming for multiple users?
In other words, if different users want scanners programmed different ways, maybe having different profiles or even different files for each?? Haven’t found way to do this. Ideas?
I do have different profiles set up for each user. Looking for something a little different.
jaspence
Michigan
When you install any program, it creates a default folder to hold the files. I have installed multiple copies by changing the folder name and treating each like a separate program.
kb7gjy
Bonners Ferry, Idaho
That I would have to say is the biggest problem I have with the software.
Having to have multiple copies of the software installed just boggles my mind. I just fail to see where I would want different profiles saved, but the freqs/sites/etc to stay the same.
Lets say I was going on a trip. One would think one could create a new scan list and save it. Then when I got back, i could just reload my "home" scan list. I know it has been discussed many times. It would be a fantastic update if that was addressed.
BlueMoon2
Midlothian, VA
Ok I do have different profile folders for each user. For example, one for Charles, one for Jerome and one for me. But in the software, how do I prevent the information from my profile from also getting written to the scanner when I write someone else’s profile.
For example, if I want to work on Jerome scanner, how do I get it to just see and write Jerome’s profile instead of his and mine?
hiegtx
Dallas, TX
There is no need for "multiple copies" of the software to be installed. In Sentinel, you'll see any Favorites list that you've created. But that does not mean that you always have to load all of them to the scanner.
Create a "Home" profile. Then, in that profile, set the systems you use in your area to be downloaded to the scanner, setting whichever ones you want to also be monitored. the rest of them (that were set to download, but not monitor when written to the scanner) are on the scanner's memory card, but not being scanned unless you access 'Set Scan Selection' and set them to also be monitored. Any lists you created for trips might be in Sentinel, but you can set your profile so that they are not loaded to the scanner (set Download to No to do that).
You could have one or more other Profiles set up for trips. On those profiles, set only the Favorites lists that you would need on the trip to be monitored, or at least downloaded. There again, any list on the scanner that you want to have available for use, but not always monitor, would be accessible Here again, any "local" lists, used in your home area, can be set to not download, so that they would not be written to the scanner.
When writing to the scanner, just select the 'erase lists on the scanner' option to delete any Favorites list on the scanner so that Favorites from the 'other profile' (Home or Trip) are not left on the scanner and being set to scan.
Some people go so far as to create separate memory cards for Home, and for one or more trips that hey take fairly often, then just switch the card. That is much easier to do on the 536HP series, as the memory card is accessible from the front panel. For the 436HP, a memory card swap involves removing the battery & then holding your mouth just right to change the card. (I don't care for the memory card holder in the 436. The one in the 536HP o Whistler's TRX series is much easier to access taking a lot of finesse.)
BlueMoon2
Midlothian, VA
Sure would be nice if you could associate all of the favorites list for one person with a profile for that person.
For example, the favorites list for Jerome could be associated with Jerome’s profile and not even come up when you select a different profile.
ofd8001
Louisville, KY
While I have not programmed scanners for others, if I was to do so, I'd be tempted to consider setting up a separate folder for each "client". Then when programming scanners, I'd select the given folder. These can be changed in Sentinel (Tools>Options).
That way unless I was having a real bad day, I would not confuse Person A's stuff with Person B's stuff. Also you can change a Favorites List for A without carrying the changes over to B, C and D and confuse them.
You can "share" exact copies of FLs by exporting to HPE, copying to the new target folder and then open the HPE file.
GTR8000
NY/NJ Database Guy
BEE00
If you're primarily concerned with the programming of the favorites lists, you could try ProScan. Saving to individual folders is easy, and groups of favorites are switched using the File>Open command. Of course you can't change any of the scanner's settings with ProScan, but I think that once most people get the scanner setup the way they like, the bulk of software usage is maintaining the favorites lists.
