RonnieUSA
Is there any software that will record what you find while searching?
Scanner dependent. What scanner?Is there any software that will record what you find while searching?
PRO-197Scanner dependent. What scanner?
Tried Win500, but it doesn't seem to log the search results.
Works great logging what you have already programed into the scanner.
I'll give that a try.Win500 only logs and records while in "Scan Mode".
To log and record search results (e.g. Limit Search, any of the service searches, sweeper mode), create such a "Search" object and add it to an enabled scan list.
Ronnie, have you not been able to get ID Tracker III to record? This is reason I wrote the application is to search for and record new frequencies and IDs while I am not home.
Yes I did, it works great.
