James_Bond_007
well a tower site does not appear to be forthcoming in the foreseeable future so i am going the direction of a self contained solar power repeater. i'm thinking of asking the landlord if i can locate it to the back of the property here. i live in scottsbluff, ne in the panhandle to give you an idea of the weather i will be dealing with.
my available hardware is a 10-50w (set for 10-15W) Vertex VXR-7000u-2 (450-470), cellwave 6 cavity bpbr duplexer, 8 bay PD type single inline folded dipole, 40ft push up mast, 1/2 inch 50 ohm hardline with n connectors.
what recommendations would you give me to make this a complete self contained solar power repeater site with emphasis on small land footprint and working within a reasonable budget. see attached pics to give you an idea of what i want to do.
i need a some suggestions of solar panel size and battery capacity as well as low consumption climate control. I'm thinking a compact self contained RV HVAC system that runs on 12/24vDC.
model numbers prices and links would be great so i can formulate a budget for this setup and a design to present to the property owner. i am not against buying or trading for used gear where possible.
from what i can tell i still need a nema enclosure, HVAC system, solar panels, batteries, charge controller, possibly cattle fencing to go around repeater.
