Audio doesn't ride on the USB so you will need an audio cable connected from the scanner to a sound input device except if using a SDS200 or BCD536HP. In that case, the Ethernet can provide the audio which doesn't use a sound input device.
If you don't have a sound input device then this will work. USB Sound Adapter
