Sp50+ software ?
mbnv992
AZ
I have a brand new in box Motorola Sp50+ “plus” UHF 10 channel model coming in. I have the original old school Sp50 programming software released in 1995 ( Version R02.00.00 ). Can this version program the Sp50+ ? It looks just like a compact Sp50 but has a plus logo on it.
Ive seen a post like this years and years ago but nothing that says if the Sp50 RSS Version R02.00.00 will in fact program an Sp50+ ?
I have the OEM Motorola Sp50 programming cable and RIB and this software works great on all my standard size Sp50’s I have.
mbnv992
AZ
Follow up for this. I’ve seen this question post on both Batlabs and here multiple times in the past. I have a definitive answer. ( to those that still care and still actually use these ancient SP50+ radios that is ) - I just got a brand spanking new UHF SP50+ in the mail. I have the standard Motorola SP50 programming stand, along with RSS Version R02.00.00. I go to program the radio and get this error message -
So - disappointed, took the radio out of that programming stand and decided to try a home brew programming cable I bought off eBay ( black ground wire, red power wire ( that isnt used here ) and yellow programming wire. Sure enough, hold these two to the bottom most side contacts and it works ! Tricky part is hitting the “read radio” then trying to hold the two contacts to the metal tabs. But - I was successfully able to read and write to the SP50+ using this programming cable - Motorola programming cable GP300 GP350 P110 P1225 SP50 | eBay
