flintery
I got a sds200 and a bcd536hb uniden reversed the wires in the plug !the tip is GROUND AND THE BASE AND MIDDLE RING IS right and left together this way you heare both sides in your headphones and speaker ! REVERS THEM !!!!! , and you be ok just make a special cable ,special if you have a grounded antenna or a amplifide speaker , just a other idea take one cable and cut it , CONNECT THE GROUND (shieldet wire )TO THE RED AND WHITE WIRE
flintery
flintery
OR DO NOT USE GROUND AT ALL !!!if you use a amp or a grounded ant ,or a power supplyI got a sds200 and a bcd536hb uniden reversed the wires in the plug !the tip is GROUND AND THE BASE AND MIDDLE RING IS right and left together this way you heare both sides in your headphones and speaker ! REVERS THEM !!!!! , and you be ok just make a special cable ,special if you have a grounded antenna or a amplifide speaker , just a other idea take one cable and cut it , CONNECT THE GROUND (shieldet wire )TO THE RED AND WHITE WIRE
flintery
