Spectra & HLN 1439 pa
toolman60
Hi All,
If possible can I get a little information please. Having a hard time getting this to sink into my pea brain.
Using an Spectra or Astro Spectra hi power trunk mount unit with the A3 head I will need the following from http://www.batlabs.com/arc/specsirn.pdf . In looking at the drawing it is listing :
(I do not want to hack and fight a new srecord for the radio want to leave it with original codeplugs srecords.)
DEK 1241D with a cable part number of HKN6145A and a switchbox HLN6819A with cable part number 6146A and it of course shows connector (B radio) and connector (A siren). Is this all 1 assembly cable or do I have to tap into the Spectra Siren cable HKN4363C with the hln6145a & 6146a cables. Jumping back and forth between forums looking at these options I am getting confused.
Radio #2 Spectra or Astro Spectra ( this radio will have a-4 to a7 head hi power trunk mount I am little confused with what cables I need for the DEK 1241D in this setup what cable would I need between the DEK and siren and radio please.
And I may just look for some a9 radios to eliminate the DEK as I am mainly wanting pa/ and air horn but at the moment I am using what's in the junk boxes.
If anyone would be so kind as to point me in the correct direction for what else I may need to purchase as far as cables go will be greatly appreciated.
Tim
w6cjq
San Ramon CA
I just bought a hi power W3 VHF configured that way I am still trying to sort it out but apparently it does work that way and the code plug indicates it was active. . I have PMLN4959a cable with which is a y cable that goes to the siren module, radio and W3 (contact me if you need it I am not going to use it.) It also has something called a key extension cable that I think integrates the siren switches and ignition sense to the radio. I posted the question to see if anyone new what it was
BTW I purchased a seprerate low price PA amp to do what you are trying to do it is not as pretty but it is low cost
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I stand corrected. Just checked the Siren/PA manual and sure enough, there it is.
toolman60
siren/pa
What's the actual question? What are you trying to do?
I am trying to figure out which cables I need to connect the radio to the siren/pa and switch box and DEK.
I am wanting to use the pa function and the air horn function of the pa.
Tim
toolman60
Hi,
Would you mind sending me a pm with what how much you want for the cable?
Tim
(KJ4DHF)
