Splitter Recommendations
hoser147
Grand Lake St. Marys Ohio
Would it be possible to post the links to these 3, and/ or take a look at the post thewenk posted above there is a bunch of info on a couple of the sites............Hoser
N8DRC
Grass Lake
Hello
The models are EDA-FT08000 XSP, EDA-FT08100 XSP, and EDA-UG2802 XSP.. Cabletvamps has them listed..
thewenk
Idaho DB Admin
Eastern Idaho
N8DRC said:
Hello
FT08000 XSP - This is the one you want. It's probably cheaper than the FT08100 and you don't need the active return feature of the 8100 for use as a scanner splitter/amp. You only care about active return if you are using it for cable TV.
UG2802 - This has unity gain and provides no amplification, but just compensates for the splitter loss. This is actually a good choice if you don't want/need any extra amplification. If you want amplification don't buy this one.
Dave
hoser147
I agree with thewenk you dont need a passive return, no outgoing signal.........If you have a long run of coax or other splitters get the amplified one.........Hoser
