ProScan: SQK
TongSlinger
Longtime Listener
35.393528, -99.467468
I am trying to set up a few systems in Proscan and i want to set OHP OKWIN SQK to 3. The SQK is auto populated and would like to know how to change it. Does P25 systems auto populate? There are no QK's set to 0 in this system. Where does it get this value from?
sonm10
Central MN Monitor
Sauk Centre, Minnesota
You need to expand the 'tree'. Press the + on the far left.
Also important to know which model you are using. Depending on the model, 'system' QK could be under system or site. But yah, start by expanding the tree.
sonm10
Central MN Monitor
The 996 SQK is actually by 'site'. As seen in your screenshot, most are already set for SQK 3, but there is a couple that needs changing. So for the Anadarko and Jay sites, expand the tree, and change qk to 3.
I should note, this is actually a bad way to program. Each site SHOULD have its own QK. Otherwise it will try to scan all those sites simultaneously, when only one or two should do.
TongSlinger
Longtime Listener
They had individual number and i couldn't set the entire SQK to what i wanted. I'm trying to figure out how to change the SQK. In fact heres the original configuration i started with. As you can see all SQK are default to 1 except the first on and i dont know how it got set to 0. I want to set all system to different QK's
